DefaultZone Property
The DefaultZone property indicates whether this is a default Payment Module zone.
    SiteCashZone.DefaultZone [=bool]
    Boolean value that specifies or retrieves the default zone status.
    The following example determines whether the first existing zone is a default zone and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Zones.Item(1).DefaultZone);
