AttachScriptInterfaces Method
The AttachScriptInterfaces method attaches the SiteKiosk objects to a webbrowser object.
SiteKiosk.AttachScriptInterfaces(webbrowser)
webbrowser |
WebBrowser object that contains the webbrowser. |
The following example attaches the SiteKiosk objects to the webbrowser of the first window in the window list.
firstwin = SiteKiosk.WindowList.Windows.Item(1);
webbr = firstwin.SiteKioskWindow.SiteKioskWebBrowser.WebBrowser;
SiteKiosk.AttachScriptInterfaces(webbr);
