DeleteTempInternetFiles Method
The DeleteTempInternetFiles method deletes temporary internet files.
[long=] SiteKiosk.DeleteTempInternetFiles(showdialog, cache, cookies,
endsession, history, callback)
showdialog |
Boolean value that specifies if a dialog should be shown. |
cache |
Boolean value that specifies if the cached files should be deleted. |
cookies |
Boolean value that specifies if the cookies should be deleted. |
endsession |
Boolean value that specifies if the session should be closed. |
history |
Boolean value that specifies if the history should be deleted. |
callback |
Callback function that will be called after deleting the files. |
Returns a Long value containing the job ID.
The callback function has two parameters containing the job ID and the number of deleted files.
The following example deletes all temporary internet files, closes the current session and shows the number of deleted files in an alert window.
function callbackfunction(jobID, deletedfiles)
alert(jobID + 'successfull, ' + deletedfiles + ' files deleted');
SiteKiosk.DeleteTempInternetFiles(true, true, true, true,
true, callbackfunction);
