LoadScript Method
The LoadScript method loads a script file.
    [obj=] SiteKiosk.LoadScript(path)
    path String that specifies the path of the script file.
    Returns an object containing all members of the script file.
    Possible script file types are .js and .vbs. Useful scripts can be downloaded at siteskin.com.
    The following example shows how to load a script and access a member defined in the script.
    mydisp = SiteKiosk.LoadScript("c:/myscript.js");
    alert(mydisp.membername);
