OnAddPlugin Event
Fires when a plugin is added.
SiteKiosk.OnAddPlugin = handler
plugin |
String that contains the name of the added plugin. |
The following example shows its name when a new plugin has been added.
<div id="id_plugin">Add a plugin</div>
SiteKiosk.OnAddPlugin = OnAddPlugin;
function OnAddPlugin(plugin)
id_plugin.innerHTML = "Added plugin: " + plugin;
