OnConfigLoaded Event
Fires when the configuration has been loaded directly after starting SiteKiosk.
    SiteKiosk.OnConfigLoaded = handler
    The following example shows an alert window directly after starting SiteKiosk.
    SiteKiosk.OnConfigLoaded = OnConfigLoaded;
    function OnConfigLoaded()
       alert("Configuration has been loaded");
