OnRemovePlugin Event
Fires when a plugin is removed.
    SiteKiosk.OnRemovePlugin = handler
    plugin String that contains the removed plugin.
    The following example shows the name of the plugin thas has been removed.
    <div id="id_plugin">Remove a plugin</div>
    SiteKiosk.OnRemovePlugin = OnRemovePlugin;
    function OnRemovePlugin(plugin)
       id_plugin.innerHTML = "Removed plugin: " + plugin;
