OnReset Event
Fires when SiteKiosk has been reset.
    SiteKiosk.OnReset = handler
    The following example shows an alert window when SiteKiosk has been reset.
    SiteKiosk.OnReset = OnReset;
    function OnReset()
       alert("SiteKiosk has been reset");
