ShowPasswordDialog Method
The ShowPasswordDialog shows the SiteKiosk password dialog.
    SiteKiosk.ShowPasswordDialog()
    If no password has been set in the configuration, SiteKiosk will be terminated immediately.
    The following example shows the SiteKiosk password dialog.
    SiteKiosk.ShowPasswordDialog();
