SiteKioskDirectory Property
The SiteKioskDirectory property contains the main directory of the SiteKiosk application.
[Str=] SiteKiosk.SiteKioskDirectory
String that retrieves the name of the directory.
The following example reads the SiteKioskDirectory value and shows it in an alert window.
alert(SiteKiosk.SiteKioskDirectory);
