BuildDateTime Property
The BuildDateTime property contains the build date and time of the SiteKiosk Configuration Wizard.
    [str=] SiteKioskConfig.BuildDateTime
    String that retrieves the date and time.
    The following example shows the build date and time in an alert window.
    alert(SiteKioskConfig.BuildDateTime);
