IsPageVisible Method
The IsPageVisible method determines whether a specified configuration page is visible.
[boolean=] SiteKioskConfig.IsPageVisible(name)
ID |
String that specifies the name of the page. |
Returns a Boolean value that is true if the page is visible and false if not.
The following example shows the visibility of the favorites page in an alert window.
alert(SiteKioskConfig.IsPageVisible("Favorites"));
