OnCancel Event
Fires when the cancel button has been clicked.
    SiteKioskConfig.OnCancel = handler
    closeable Boolean value that indicates whether the wizard can be closed.
    The following example shows an alert window when the wizard is about to be closed.
    SiteKioskConfig.OnCancel = OnCancel;
    function OnCancel(closeable)
       alert(closeable);
