OnOk Event
Fires when the ok button has been clicked.
SiteKioskConfig.OnOk = handler
closeable |
Boolean value that indicates whether the wizard can be closed. |
The following example shows an alert window when the ok button has been clicked.
SiteKioskConfig.OnOk = OnOk;
function OnOk(closeable)
alert(closeable);
