OnWizardClose Event
Fires when the wizard is closed.
    SiteKioskConfig.OnWizardClose = handler
    The following example shows an alert window when the wizard is about to be closed.
    SiteKioskConfig.OnWizardClose = OnWizardClose;
    function OnWizardClose()
       alert("Closing wizard");
