OnWizardInit Event
Fires when the wizard has been started.
    SiteKioskConfig.OnWizardInit = handler
    The following example shows an alert window when the wizard has been started.
    SiteKioskConfig.OnWizardInit = OnWizardInit;
    function OnWizardInit()
       alert("Started");
