SiteKioskDirectory Property
The SiteKioskDirectory property contains the main directory of the SiteKiosk application.
    [Str=] SiteKioskConfig.SiteKioskDirectory
    String that retrieves the name of the directory.
    The following example reads the SiteKioskDirectory value and shows it in an alert window.
    alert(SiteKioskConfig.SiteKioskDirectory);
