SystemDefaultLCID Property
The SystemDefaultLCID property contains the default system locale ID.
    [long=] SiteKioskConfig.SystemDefaultLCID
    Long value that retrieves the locale ID.
    The following example shows the default system locale ID in an alert window.
    alert(SiteKioskConfig.SystemDefaultLCID);
