CreatePopupMenu Method
The CreatePopupMenu method creates an object that contains a popup menu.
    [obj=] SiteKiosk.SiteKioskUI.CreatePopupMenu()
    Returns a SKMenu object that represents the new popup menu.
    A popup menu can be used as a submenu of a normal menu.
    The following example creates a HTML dialog containing a menu with submenus.
       switch (ai_CommandID)
          case 3: alert('Bye'); break;
    mydialog.Title = true;
