HideConfigWarnDlg Property
The HideConfigWarnDlg property specifies if the configuration warning dialog should be shown.
SiteKiosk.SiteKioskUI.HideConfigWarnDlg [=bool]
Boolean value that specifies or retrieves if the configuration warning dialog should be shown.
The configuration warning dialog must be implemented into each skin for this property to show an effect. See the Default, IE and IE7 skin for examples.
The following example changes the visibility of the configuration warning dialog.
skui = SiteKiosk.SiteKioskUI;
function switchhcwd()
skui.HideConfigWarnDlg = !skui.HideConfigWarnDlg;
<a href="javascript:switchhcwd()">switch visibility</a>
SiteKiosk v6.6 (and later versions).
