BorderVisible Property
The BorderVisible property reads or sets the visibility status of the border.
    SiteKioskWindow.SiteKioskWebBrowser.BorderVisible [=boolean]
    Boolean value. True if the border is visible.
    False if the border is invisible.
    The following example reads the BorderVisible property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.BorderVisible);
