Busy Property
The Busy property indicates if the browser is currently busy.
    [boolean=] SiteKioskWindow.SiteKioskWebBrowser.Busy
    Boolean value. True if the browser is busy.
    False if the browser is not busy.
    The following example reads the Busy property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.Busy);
