FlatStyle Property
The FlatStyle property indicates if the browser border looks flat or not.
    SiteKioskWindow.SiteKioskWebBrowser.flatstyle [=boolean]
    Boolean value. True for a flat style layout.
    False for a normal layout.
    The following example reads the FlatStyle property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.FlatStyle);
