IsButtonEnabled Method
The IsButtonEnabled method determines if a specified button is shown as enabled or disabled.
[boolean=] SiteKioskWindow.SiteKioskWebBrowser.IsButtonEnabled(ID)
ID |
Integer that specifies the ID of the button. |
Returns a Boolean value that is true if the button is enabled and false if not.
The button IDs defined in the skin files are as follows:
Forward = 1
Back = 2
Stop = 3
Refresh = 4
Home = 5
Search = 6
Print = 7
Email = 8
Programs = 9
Mediamail = 10
Logout = 11
Close = 12
Favorites = 13
The following example determines if a specified button exists and shows it in an alert window.
alert(SiteKioskWindow.SiteKioskWebBrowser.IsButtonEnabled(7));
