MenuBar Property
The MenuBar property indicates if a menu bar is shown.
    [boolean=] SiteKioskWindow.SiteKioskWebBrowser.MenuBar
    Boolean value. True if there is a menu bar.
    False if there is no menu bar.
    The following example reads the MenuBar property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.MenuBar);
