Navigate Method
The Navigate method navigates to a specified address.
SiteKioskWindow.SiteKioskWebBrowser.Navigate(abs_URL, avb_IsUser)
abs_URL |
String that contains the URL. |
avb_IsUser |
Boolean that specifies if a user started the navigation (default false). |
Note that the SiteKioskWindow object can only be used from within a browser skin file.
To use the SiteKioskWindow object in other files it can be referenced through the main object SiteKiosk. E.g.: SiteKiosk.WindowList.MainWindow.SiteKioskWindow.SiteKioskWebBrowser.Navigate(SiteKiosk.URLs.Email, false);
The following example navigates to www.cnn.com.
myurl = "http://www.cnn.com";
SiteKioskWindow.SiteKioskWebBrowser.Navigate(myurl, false);
