OnButtonStatusChange Event
Fires when the status of a button changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnButtonStatusChange = handler
    ID Integer that contains the ID of the changed button.
    The button IDs defined in the skin files are as follows:
    Forward = 1
    Back = 2
    Stop = 3
    Refresh = 4
    Home = 5
    Search = 6
    Print = 7
    Email = 8
    Programs = 9
    Mediamail = 10
    Logout = 11
    Close = 12
    The following example changes the forward button image if its status changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnButtonStatusChange = OBTSChange;
    function OBTSChange(ai_ButtonID)
       if(ai_ButtonID==1)
          window.document.images.1.src="new_image.gif";
