OnCheckSurfArea Event
Fires when SiteKiosk checks the surf area.
SiteKioskWindow.SiteKioskWebBrowser.OnCheckSurfArea = handler
URL |
String that contains the new URL. |
toplevel |
Boolean value that indicates whether the main frame has been navigated. |
target |
String that contains the name of the target frame. |
browserobj |
Object that contains the browser. |
The navigation will only be done if the event function returns true.
The following example shows an alert window when SiteKiosk checks the surf area.
SiteKioskWindow.SiteKioskWebBrowser.OnCheckSurfArea = OnCheckSurfArea;
function OnCheckSurfArea(URL, toplevel, target, browserobj)
alert('Surf area checked');
