OnFullScreenModeChange Event
Fires when the screen mode changes from normal to full or vice versa.
    SiteKioskWindow.SiteKioskWebBrowser.OnFullScreenModeChange = handler
    avb_Full Boolean value that is true if the browser runs in full screen mode. False if full screen mode is not disabled.
    The following example shows an alert window when the full screen mode changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnFullScreenModeChange = OFSMCh;
    function OFSMCh(avb_Full)
       alert(avb_Full);
