OnProgressChange Event
Fires when the navigation progress changes.
SiteKioskWindow.SiteKioskWebBrowser.OnProgressChange = handler
al_Cur |
Long value that contains the current value of the progress status. |
al_Max |
Long value that contains the maximum value of the progress status. |
The following example shows the current status of the progress change.
<div id="id_statustext"></div>
SiteKioskWindow.SiteKioskWebBrowser.OnProgressChange = OPChange;
function OPChange(al_Cur, al_Max)
if (al_Cur < al_Max && al_Max > 0)
id_statustext.innerHTML=(Math.Round(al_Cur/al_Max*100))+"%";
