OnShowContextMenu Event
Fires when the context menu is displayed.
SiteKioskWindow.SiteKioskWebBrowser.OnShowContextMenu = handler
menutype |
Long value that contains the menu type. |
posx |
Long value that contains the horizontal position. |
posy |
Long value that contains the vertical position. |
obj |
Object containing the clicked element. |
Possible menu types are:
0 : default
1 : image
2 : control
3 : table
4 : textselect
5 : anchor
The following example shows an alert window every time the context menu is displayed.
SiteKioskWindow.SiteKioskWebBrowser.OnShowContextMenu = OnContextMenu;
function OnContextMenu(menutype, posx, posy, obj)
alert('Context menu displayed.');
