OnStatusTextChange Event
Fires when the text in the status bar changes.
SiteKioskWindow.SiteKioskWebBrowser.OnStatusTextChange = handler
abs_Text |
String that contains the text of the status bar. |
The following example shows an alert window when the status bar text changes.
SiteKioskWindow.SiteKioskWebBrowser.OnStatusTextChange = OSTChange;
function OSTChange(abs_Text)
alert(abs_Text);
