OnTitleChange Event
Fires when the current title changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnTitleChange = handler
    abs_Text String that contains the new title.
    The following example shows the current title.
    <div id="id_titletext"></div>
    SiteKioskWindow.SiteKioskWebBrowser.OnTitleChange = onTitleChange;
    function onTitleChange(abs_Text)
    	id_titletext.innerHTML = abs_Text;
