OnURLAddedToHistory Event
Fires when an URL is added to the browser history.
SiteKioskWindow.SiteKioskWebBrowser.OnURLAddedToHistory = handler
abs_NewURL |
String that contains the URL. |
The following example shows an alert window when an entry was added to the history.
SiteKioskWindow.SiteKioskWebBrowser.OnURLAddedToHistory = OURLAdded;
function OURLAdded(abs_NewURL)
alert("New history entry: " + abs_NewURL);
