OnURLHistoryCleared Event
Fires when the history of the browser is cleared.
    SiteKioskWindow.SiteKioskWebBrowser.OnURLHistoryCleared = handler
    The following example shows an alert window when the history is cleared.
    SiteKioskWindow.SiteKioskWebBrowser.OnURLHistoryCleared = OnHCleared;
    function OnHCleared()
       alert("The history has been cleared.");
