ProgressCur Property
The ProgressCur property contains the current value of the progress bar.
    [long=] SiteKioskWindow.SiteKioskWebBrowser.ProgressCur
    Long value that retrieves the current progress bar value.
    The following example reads the ProgressCur property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.ProgressCur);
