ProgressMax Property
The ProgressMax property contains the maximum value of the progress bar.
[long=] SiteKioskWindow.SiteKioskWebBrowser.ProgressMax
Long value that retrieves the maximum value of the progress bar.
The following example reads the ProgressMax property and shows it in an alert window.
alert(SiteKioskWindow.SiteKioskWebBrowser.ProgressMax);
