ScrollBar Property
The ScrollBar property indicates if a scrollbar is shown.
    SiteKioskWindow.SiteKioskWebBrowser.ScrollBar [=boolean]
    Boolean value. True if the scroll bar is visible.
    False if the scroll bar is not visible.
    The following example reads the ScrollBar property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.ScrollBar);
