StatusBar Property
The StatusBar property indicates if a status bar is shown.
    [boolean=] SiteKioskWindow.SiteKioskWebBrowser.StatusBar
    Boolean value. True if the status bar will be displayed.
    False if there is no status bar.
    The following example reads the StatusBar property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.StatusBar);
