ToolBar Property
The ToolBar property indicates if a tool bar is shown.
    [boolean=] SiteKioskWindow.SiteKioskWebBrowser.ToolBar
    Boolean value. True if the tool bar is visible.
    False if the tool bar is not visible.
    The following example reads the ToolBar property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.ToolBar);
