URLAddressBar Property
The URLAddressBar property indicates if an address bar is shown.
    [boolean=] SiteKioskWindow.SiteKioskWebBrowser.URLAddressBar
    Boolean value. True if the address bar is visible.
    False if the address bar is not visible.
    The following example reads the URLAddressBar property and shows it in an alert window.
    alert(SiteKioskWindow.SiteKioskWebBrowser.URLAddressBar);
