IsMainWindow Property
The IsMainWindow property contains a boolean value indicating if the window is the main window or not.
    [boolean=] SiteKioskWindow.IsMainWindow
    Boolean value. True if the window is the main window.
    False if the window is not the main window.
    The following example reads the IsMainWindow property and shows it in an alert window.
    alert(SiteKioskWindow.IsMainWindow);
