Move Method
The Move method moves and resizes the window.
    SiteKioskWindow.Move(iLeft, iTop, iWidth, iHeight)
    iLeft Integer value that specifies the new coordinate for the left margin.
    iTop Integer value that specifies the new coordinate for the top margin.
    iWidth Integer value that specifies the width of the window.
    iHeight Integer value that specifies the height of the window.
    The following example calls a method of the SiteKioskWindow object that will move the window to new coordinates and resize it to 150*150 pixels provided it is not the main window.
    if(!SiteKioskWindow.IsMainWindow) SiteKioskWindow.Move(50,50,150,150);
