OpticalZoomMin Property
The OpticalZoomMin property contains the minimum zoom rate in percent.
[int=] SiteKioskWindow.OpticalZoomMin
Integer that retrieves the minimum zoom rate.
This functionality is available for Internet Explorer 7 (and later versions).
The following example displays the minimum zoom rate.
alert(SiteKioskWindow.OpticalZoomMin);
SiteKiosk v6.6 (and later versions).
