Visible Property
The Visible property indicates if the window is visible.
    [boolean=] SiteKioskWindow.Visible
    Boolean value. True if the window is visible.
    False if the window is not visible.
    The following example reads the Visible property and shows it in an alert window.
    alert(SiteKioskWindow.Visible);
