CallRate Property
The CallRate property indicates how much the current call costs per tick.
    [double=] SiteKiosk.Plugins("SitePhone").CallRate
    Double value that retrieves the current call rate.
    The following example keeps a HTML element containing the call rate up to date.
    <div id="CallRate">0</div>
    SitePhone.OnCallStateChanged = OnCallStateChanged;
    function OnCallStateChanged()
       CallRate.innerHTML = SitePhone.CallRate;
