CallStatus Property
The CallStatus property indicates the status of the current call.
    [long=] SiteKiosk.Plugins("SitePhone").CallStatus
    Long value that retrieves the call status.
    Possible status flags are:
    CS_UNKNOWN = -1;
    CS_UNPLACED = 0;
    CS_ROUTING = 1;
    CS_EARLY_MEDIA = 2;
    CS_FAILED = 3;
    CS_RINGING = 4;
    CS_IN_PROGRESS = 5;
    CS_ON_HOLD = 6;
    CS_FINISHED = 7;
    CS_MISSED = 8;
    CS_REFUSED = 9;
    CS_BUSY = 10;
    CS_CANCELLED = 11;
    CS_LOCAL_HOLD = 12;
    CS_REMOTE_HOLD = 13;
    CS_VOICEMAIL_BUFFERING_GREETING = 14;
    CS_VOICEMAIL_PLAYING_GREETING = 15;
    CS_VOICEMAIL_RECORDING = 16;
    CS_VOICEMAIL_UPLOADING = 17;
    CS_VOICEMAIL_SENT = 18;
    CS_VOICEMAIL_CANCELLED = 19;
    CS_VOICEMAIL_FAILED = 20;
    CS_TRANSFERRING = 21;
    CS_TRANSFERRED = 22;
    CS_INCOMING = 24;
    If you want to react when this property changed, you can use the OnCallStateChanged Event.
    The following example keeps a HTML element containing the call state up to date.
    <div id="CallState"></div>
    SitePhone.OnCallStateChanged = OnCallStateChanged;
    CS_UNPLACED = 0;
    CS_ROUTING = 1;
    CS_EARLY_MEDIA = 2;
    CS_FAILED = 3;
    CS_RINGING = 4;
    CS_IN_PROGRESS = 5;
    CS_ON_HOLD = 6;
    CS_FINISHED = 7;
    CS_MISSED = 8;
    CS_REFUSED = 9;
    CS_BUSY = 10;
    CS_CANCELLED = 11;
    CS_LOCAL_HOLD = 12;
    CS_INCOMING = 24;
    function OnCallStateChanged()
       switch (SitePhone.CallStatus)
          case CS_ON_HOLD:
          case CS_LOCAL_HOLD:
          case CS_REMOTE_HOLD:
             CallState.innerHTML = "Call on hold";
             break;
          case CS_ROUTING:
             CallState.innerHTML = "Connecting...";
             break;
          case CS_RINGING:
             CallState.innerHTML = "Ringing...";
             break;
          case CS_IN_PROGRESS:
             CallState.innerHTML = "Call in progress";
          case CS_FINISHED:
             CallState.innerHTML = "Call finished";
             break;
          case CS_FAILED:
          case CS_REFUSED:
          case CS_MISSED:
             CallState.innerHTML = "Connection problem";
             break;
    SiteKiosk v7.5 (and later versions).
