MessageDeliveryFailureReason Property
The MessageDeliveryFailureReason property indicates for which reason the text message sending failed.
[long=] SiteKiosk.Plugins("SitePhone").MessageDeliveryFailureReason
Long value that retrieves the last message delivery failure reason.
Possible status flags are:
MDFR_UNKNOWN = -1;
MDFR_MISC_ERROR = 0;
MDFR_SERVER_CONNECT_FAILED = 1;
MDFR_NO_SMS_CAPABILITY = 2;
MDFR_INSUFFICIENT_FUNDS = 3;
MDFR_INVALID_CONFIRMATION_CODE = 4;
MDFR_USER_BLOCKED = 5;
MDFR_IP_BLOCKED = 6;
MDFR_NODE_BLOCKED = 7;
The following example sends a text message and alerts possible errors.
success = SitePhone.SendTextMessage("+1 918 555 5000", "Hello world!");
if(!success)
switch(SitePhone.MessageDeliveryFailureReason)
case MDFR_MISC_ERROR:
alert("Message delivery failed: Misc error");
break;
case MDFR_SERVER_CONNECT_FAILED:
Server connection could not be established");
break;
case MDFR_NO_SMS_CAPABILITY:
No short message capability");
break;
case MDFR_INSUFFICIENT_FUNDS:
alert("Message delivery failed: Insufficient funds");
break;
case MDFR_INVALID_CONFIRMATION_CODE:
Invalid confirmation code");
break;
case MDFR_USER_BLOCKED:
alert("Message delivery failed: User blocked");
break;
case MDFR_IP_BLOCKED:
alert("Message delivery failed: IP blocked");
break;
case MDFR_NODE_BLOCKED:
alert("Message delivery failed: Node blocked");
break;
default:
alert("Message delivery failed");
