State Property
The Docked property indicates whether the touch screen keyboard is docked or not.
[long=] SiteKiosk.Plugins("SitePhone").State
Long value that retrieves the plugin state.
Possible status flags are:
S_UNKNOWN = -1;
S_OFFLINE = 0;
S_CONNECTING = 1;
S_PAUSING = 2;
S_ONLINE = 3;
If you want to react when this property changed, you can use the OnStateChanged Event.
The following example logs the SitePhone state.
SitePhone.OnStateChanged = OnStateChanged;
S_OFFLINE = 0;
S_CONNECTING = 1;
S_PAUSING = 2;
S_ONLINE = 3;
function OnStateChanged()
switch (SitePhone.State)
case S_OFFLINE:
SiteKiosk.Logfile.Notification("SitePhone is now offline.");
break;
case S_CONNECTING:
SiteKiosk.Logfile.Notification("SitePhone is now connecting.");
break;
case S_PAUSING:
SiteKiosk.Logfile.Notification("SitePhone is now pausing.");
break;
case S_ONLINE:
SiteKiosk.Logfile.Notification("SitePhone is now online.");
break;
default:
SiteKiosk.Logfile.Notification("SitePhone state is unknown.");
