UserCallsEnabled Property
The UserCallsEnabled property indicates whether user calls are enabled or not.
[boolean=] SiteKiosk.Plugins("SitePhone").UserCallsEnabled
Boolean value that retrieves whether user calls are enabled or not.
The following example checks whether user calls are enabled and calls a test user.
if (SitePhone.UserCallsEnabled)
SitePhone.StartCall("echo123");
